Keep an eye on the swing arm bearings and bushings along with the carrier bearings.
I noticed my quad was a little hard to push lately and that there was movement in the swingarm from side to side. So I bought a Moose carrier rebuild kit (comes with bearings and dust covers), all new o-rings, swing arm pivot rebuild kit from All Balls/Moose (comes with 4 instead of two bearings, bushings and the washers and rubber inserts for the outside caps) and a I picked up a new pivot bolt. I bought a new XC Lonestar adjustable axle hubs and sprocket hub as well.
This is what was left of my carrier bearings. The first two came out in pieces as usual but the last two came out fine. The bearings are completely seized and are without a doubt the reason my carrier kept rotating slightly after being tightened down.
Inside the swingarm pivot area there are two needle bearings but the new All Balls kit comes with 4 which is a much better set up and seems much more sturdy. My Needle bearings were literally GONE when I removed the swingarm. There were only a few left in it, it was riding on packed mud and chunks of bushing.
